1256 loader question
Anonymous-0
would like to put a joystick on 1256 so the dual hydraulics on the rear can be used for other purposes. right now the loader is being controled by both of them. Where can I plumb in and get hyd pressure to power the joystick? Also where can I return the hyd oil from the joystick? thanks for any help! Joe
Need a power beyond plate to go on spool valves. CIH made them, sorta spendy if they are still available. Have been posts on here previously about aftermarket ones. By the way, your outside spool valve must be open on both sides to use the power beyond plate.
Get a PTO pump and separate control valve and reservoir. Best way to go on an old IH. The factory IH pump doesn't put out enough GPM in my opinion for a loader.
