W6 swinging drawbar
Cooper#6
New User
Does the drawbar hardware, ie. angle iron and flat bar that attached to the drawbar also fit the W4??? Are the one of the same?? Regards,
I do know that the drawbar off a W6 is bent differently, longer, and maybe even thicker than one off a W4. I really struggled finding one for my W4 and ended up making one. My mistake was not hardening it before paint... since the hole egged out after a short time of plowing. As for the cross piece/angle iron, I"m not sure. I could measure mine and let you know if it"s the same if you have the measurements off a W6. Let me know.
I have the parts for my W4. It has and angle on the bottom, and a flat piece on top. With spacers between the two on the ends. Is the W6 the same or is it two flat bars with spacer???. I have the swinging bar, one inch thick from under the rear end. It was added later as the code of W1 is for gasoline only. I have ordered the parts manual, not in my hands yet. cheerzzz
