McCormick C-20 Fast Hitch Plow.
georgeky
Hey guys. Does anyone have a C-20 fasthitch plow? I need the hitch prongs traced onto a piece of cardboard so I can make me a set for my plow. I also need the dimensions for the square tube they are welded to. Someone stole my hitch and I haven't been able to find one. Thanks much.
George: Sell me the plow and your problem will be over. Bear in mind I didn't make that plural, I'm not paying enough to put you on easy street forever.
George I think I have a set of prones that may fit your needs. I bought them a few years ago to adapt a one point carrier for a cub. Never used them. Send me an email with your phone number.
Hugh, I can't sell you my old plow. This set is the set that came new with dads 230 when he bought it. I also have the mowing machine. He traded the tractor off in 81 on a 484 and I ended up with the plow and mower. I have tried to find the 230, but no luck yet. No telling where it is. It looked like a new one when he traded it off. If I find me an offset I would just make a one point plow out of it.
George, Just so you know. The prongs also have a slight twist in them, looking at the plow from the front, so the plow sits level when the tractors right rear tire is in the furrow.At the moment, I`m at Children`s Hospital in Milwaukee with my 11 mo. old son, but if you can wait a few days, I can get you some pictures and measurements when I get home. Let me know if you need some help and I`d be glad to oblige.I collect fast hitch implements and have close to 30 of them.I guess you could say I`ve never met a fast hitch implement I didn`t like! Mark
Hi Mark. I hope your son is OK. I do know that is why I wanted them traced. I have lots of FH implements as well. I have had this plow for more than 30 years. I took it apart to clean and paint it and someone stole the hitch out of my barn. Send me an email and we will talk about them.
George,
did you ever get what you needed? I have a C-20 in pieces at the moment and can trace what you need.
What is said above is true about the prongs more or less. One prong is straight and the other drops a little before being welded to the bar joining them. This gives the plow a slight twist.
Actually I need an exploded view of this plow if anyone has one they can email me or post. I want to make sure I get the spring assy, etc assembled correctly.
