is the SurepC Case (rear frame) same as a C
Anonymous-0
I was wondering if these cases would interchange. the brakes definetely are different looking, but these transmission cases look a lot of like.
They're interchangeable as far as bolting up and being able to drive it, but that's about it. A C rear-end will not be machined for the disc brake surfaces like a Super. If the pedals and linkages for the band brakes (a whole different beast from the linkage on the SuperC discs) came with it, though, you'd be all right in that regard.
Not at all certain about this part, but I don't believe the castings for the rear ends of the C have all the bolsters and fittings cast or machined into them to mount the Fast Hitch. Look real closely at that.
we had a C with a fasthitch on it, which is now disabled. No idea if any mods had to be made, as it came that way to us and worked a good 30 years doing tillage and pulling 12 ton silage wagons without any hitch issues. quick glance looks like it's same as Super C. left side leveling arm can't be mounted 100% properly because the mount is part of the disk brake cover, but can be made to work apparently.
karl f
