Rear axle on A
Mark W.
Are the left and right side of the super a the same when it comes
to the final drives. I need one and after looking them over last night
I thought they looked interchangeable.
To the extent that you could bolt them up to the differential shafts and drive it, yes BUT I believe I'm correct in saying that they are not symmetrical with regards to how they're cast and tapped for mounting the drawbar and implements, so it isn't really a practical solution if you're planning on using the tractor for anything.
No, the final drives are not identical. They are mirror images of each other. A left & right swap won't work.
They might not be identical , but i dont think you are going to have any problems bolting up impliments either. I dont think the tolerances are that tight on the impliments that a little this way or that way is going to make that big of a difference.You can always modify it if it isnt exact.
