hugh Mckay-- Temp Gauge Bracket
Anonymous-0
Mr Hugh, do you know where I could get the bracket to mount a temp gauge to the governor housing, as in the pictures? This allows you to use the 9 inch long lead gauge.
Picture was taken in a cane field junk yard (read as "collection"). Looking at the line in the hood, I would guess it is from an A, AV, SA or SAV.
Couv: Those will be scarce as hen's teeth. IH only ever installed heat gauges on dual fuel tractors from the factory, unless someone requested it as an option. I'm 66 years old and have never seen an offset Farmall with a heat gauge.
My best suggestion would be fabrication. Most any shop should be able to turn that out, from the photo your showing us. They might not get it exact, but I doubt if you have too many critics. Main thing is make it so you can see it from seat, and lead will reach.
My 47 BN has one on it. Also had shutters at one time. Must have been a dual fuel? Thought I had a picture but not.
