JD 36 lader to a 460 utility
Craig Evans
New User
Can anyone tell me if a JD 36 loader will fit a 460 utility? The guy I am purchasing it from said it was mounted to a 350 utility prior. Any info would be appreciated. I have to hurry before snow flies!!! I posted this once, but it didn't go through- not sure what happened.
Directly? No, not even now as modified for the 350 Utility.
With a torch, welder, some scrap steel, and a few hours of fabrication? Yes.
Do you know what the differences would be between the 460 and the 350 as far as what modifications would be required? Are the axles the same distance back form the tractor front frame?
