My trusty '55 IH 300 U suddenly wouldn't fire the other day after running fine a couple weeks before. I've been going thru things (first time in 7 years!!!) and have hit a wall.
Can't figure out how to remove the old points. My owner's manual says nothing about it. My distributor has a little threaded pin running thru a plastic block on the outside where two wires attach with a nut and a plastic block on the inside where the points spring slips in behind the thin head of the pin. That spring is under the head very tight, even when the nut is loose. I tried tapping the threaded pin toward the distributor shaft to free the spring, but no budge. Before I start getting physical thought maybe I should ask someone who knows.
Could you please explain the points removal steps to me?
Also, any suggestions for getting the new points up on the top of the cam lobe by removing plugs and turning the crank somehow by hand? Punching the starter seems to want to stop it with the points closed every time.
Thanks for your help. Bob
