charles todd
This has fought me all the way. Obviously the engineers at IH did not plan on many loaders to be installed on the 1962 Farmall 504. Intergrating additional hydraulics and trying to make it look good was a challange. This is the happy medium between function and form.
I brought the intake from the pump to the valve. It leaves the valve through the power beyond port and goes back to the power steering flow divider. The out or relief port goes to the fill plug at the IPTO. The fitting I replaced the plug with is a 1 1/4" ORB x 3/4" MJIC, 90 degree, try to find that at NAPA. All feeder hoses are 3/4", work hoses are 1/2", fed off of a fresh 17 GPM pump running at 2000 PSI. The loader is faster than some new tractors I have used.
Enjoy the pictures... Sorry for all the dust, just baled about 160 round bale from the 3rd cut of the year.
Inlet and Power Beyond hoses
3 Spool Valve (I am reserving the 3rd for a thumb or grapple)
Pedastal and hoses (Had to give up the RH step)
Return line at the IPTO
Thanks for help from all of you. Especially Allan for saying it cannot be done without a PTO pump and reservoir to inspire me (LOL). I hope this can help someone later down the road.
Charles
Charles
