200 hydrolics block
Rascals
New User
My 200 has a block under the toolbox that is leaking. It connects the flex lines to some steel lines under the toolbox.I`d want to call it a manifold, would this be something a IH dealer might have?
You need to take it apart and determine if the part is broken, or if there is just a leaking O-ring in there somewhere. Orings can be replaced. The block/manifold is no longer available from the dealer. You'd either need to have it braized or find a good used part at a tractor salvage yard.
Or, you can bypass the block with hoses and fittings.
That block on the deck just forward of the tool box/seat support is a check valve for the 2 point. It keeps your 2 point cylinder from creeping down from hydraulic fluid leaking past the hydraulic lift valve. They are pretty common and available from most salvage yards.
RR
Thank you, that was my next question as my freinds super c does not have this block. I`ll start looking for one. thanks John
