IH 105 grinder weight chart
Anonymous-0
could anyone tell me where to find this? No sticker on the tank, reprint manual doesn't show it and Artsway has sent me a chart for a 320 and a 400/95 grinder, not sure if either are right. Will need to grind soon again and don't want to guess at adding protein. Your help is appreciated
We used to have a 105, then a 1050 later, I'm pretty sure the Arts Way 325, 105 & 1050 are the same machine as far as capacity. 2 1/2 ton I think, been a while.
Hope this helps you, Bob
called 3 dealers, no suprise Pipestone was no help, will check with Slayton and Artsway Monday, if I know that a 1050 tank is the same that would be of some help. didn't know these grinders were 45 years old but it is in really nice shape and figured it will last me a long time.
If you go to external_link go down to "other equipment" and click on feed grinders under International, one ad has a 1150 and a 1050 sitting side by side and they look the same. There also a 105 in the first ad if you want to do some comparing, they all have the same size tank as far as I can tell.
Didn't see any of the "300 series" Artsway" mills
Bob
I have a brochure of model 1150 grinder mixer (capacity of 105 bu. same as a 105 ) with a photo showing a capacity chart decal on the mixer. It gives weight of feed stuffs at gauge marks beside the windows in the mixer tank.
105 bushel capacity mixer full holds 5213 lbs. ground shelled corn, 3962 lbs. ground ear corn, 5839 lbs unground shelled corn, 2346 lbs. ground oats, 3754 lbs. ground barley, 5839 lbs. ground milo.
I can send you the photo if you like. Reply if interested.
