Phil in the hill
New User
Good morning, I have had my 48' H in my unheated garage for the 2 past months. I had just bought it and not used it much due to overheating. In PA the temps. ranged from 10 to 60 degrees. I had not tried to start it in that time, so it has been sitting awhile. This past weekend I put on my radiator that I had reapired which was off for about 4 weeks. Before I put it on I pushed the tractor outside and flushed it with water. Also in the same day I took off the valve cover, cleaned the valves (which had pretty heavy grim), put on a new gasket, recovered, and changed the oil. I tried to start the tractor and it will not turn over. It gives a weak try but will not go. The tractor is still a 6v with 30 weight oil. Any suggestions to get it started? Thank-you
