farmall h carb problems
nk42h
New User
My carb on my h leaks out of the choke control on the side. how do I fix this? also the the support bracket for the float is bent but i straighted it ok but if i have to do a rebuild i would like to know if i could get that part. i already have checked the case dealer anf the part is retired.
With the bracket being bent, the float is probably out of adjustment, letting in to much fuel. Not sure if i understand the support bracket unless you mean the prongs that hold the float coming from the carb side, if thats the case and it breaks it does not come in a kit and a replacement carb would be needed or at least that half of carb.
