will this conversition kit fit an m
jamesinmo
New User
hello every one i fond this add on craigs list and it looks like a great deal for 300 dollars. he said it fit an "h" and its on an "h" in the pic. i emailed the guy and he says he doesn't know if it will fit an "m" . also could you tell me if i would have to take the old draw bar off my "m" in order to put this hitch on if it will fit...
thanks
james
3 point hitch
Your link says it has been deleted. 3 point hitches will "fit" anything from a C through at least the 560 because the spacing between the axle clamps is the same. Whether or not the original drawbar can be used depends on the hitch. With Saginaw, yes. For the Saginaw the original drawbar brackets are removed and the U shaped piece bolts directly to the hitch. The swinging part can also be used. Some have their own drawbar, some don't.
