Anonymous-0
Hello, I just picked up a 1940 M and i have noticed that it has parts that are different. The top deck is not slotted but has the shifting pattern through 4th gear, no 5th indicated(I know that 5th is there). Tractor has an 11,000 serial number and most casting codes are J. The engine is a 248 block but has a B casting code and the serial number is not stamped into the pad above the dist. I bought the tractor as parts and did not really intend to fix it up but the tranny cover has me intrigued so I thought that I would try to see what every one else thought about it. Thanks, Mike
