international 966 shifting problems
My 966 goes great forward in high, but reverse and low forward acts like the e brake is catching and it pops out of gear, but the shifter doesn't move, any info would be greatly appreciated!
(quoted from post at 17:15:09 02/13/09) My 966 goes great forward in high, but reverse and low forward acts like the e brake is catching and it pops out of gear, but the shifter doesn't move, any info would be greatly appreciated!
Is your linkage OK? I would pull the filter and inspect it for metal particles. It is quite possible that the bearings on the lower shaft in the range transmission have failed. That would affect both low and reverse. High is direct drive from the speed transmission to the pinion shaft. You can see a bit by removing the cover on the left side of the rear frame.
