SC/SA Carb Adjustment
Bud W
Is there any way to adjust the fuel/air ratio on the Zenith Carbs for these tractors. I don't believe there is an adjustment screw but is there another way to make the adjustment? I believe I'm running rich on my SAV.Thanks
There is an aftermarket fuel adjustment needle for those carbs. The only other thing you might do is take the carb apart and check the float level and condition of the float valve and seat.
