tractor vet
lenray
tractor vet I have a JD 3010 electrical question over on the JD FORUM.
I know you are the IHC expert--if you would look over there i sure would appreciate it.
Thanks lenray
Just what the heck do you want me to have Nightmare's I have worked on a couple 3010's and 4010 's and i would like to forget that i did.
i HAVE GOT FAITH IN YA MAN---Electrical is electrical no mater the color isn't it.
You helped me on my 756. Did you read the question. lenray
Yes i did . On this one it is one of them things that ya have to be there with a test lite and a meter and the wiring diagram . Being that it is a gasser it will make it a lot easier . Them old 3010's and 4010 's they were fun . I worked on one of my customers 4010 diesel one time and went to the Deere shop to get the diagram and they only had a third of it had to go to two other dealers for the rest as they did not have a complet one them selfs. The big thing here is how the power comes up from the hot post and where the ing. switch gets it power from . The 10 sieres uses the same delco 56 ends So it maybe that it is just dirt and corrosion and loose connections . Got to keep in mind here that we play with OLD tractors and they are just about as bad as our old wifes ya always had to fuss with them.
