removing throw out bearing on a 986
soem one give me some insite on hoewto ge teh trhow out bearing our i have did it but it has been a while do you have ot remove the shaft also how do you replace the rear main seal ont he same tractor do you have to remove the plate or doit with it in place also is there any other seals that i can replace why i got the tractor split thanks for any help[
Well the throw out bearing is just popped off the carrier with a few lite taps as for the pilot bearing ya need a puller . as for the rear main seal this can be done with out removing the rear engine plate with a good pry bar and a sharp chisel . But to install it ya need the seal installer to press it and the ware ring on all at the same time. .The other seals that should be replaces is the PTO input seal and the transmission input shaft seal , now while ya got that apart ya may want to replace the PTO input bearing . That bearing replacement is cheap insurance against a leaking seal later.
