Chris NW Ind
Does anyone here have a picture or can tell me where precisely the valve for my W9 is supposed to be mounted. Mine has a standard H/M valve and is mounted fairly high on the left fender. I know the W series have a longer operator's handle and should consequently be mounted much lower. Plus the supply/return hoses on my tractor don't run through the left platform, but instead are over the top. Somebody also hacked up the opening in the platform to more easily remove the hoses.
You can see most of this in the picture. I should add that it all works fine.
Thanks in advance, Chris B.
<a href="http://s304.photobucket.com/albums/nn170/cbfarmall/?action=view¤t=W9_10-27-08_3.jpg" target="_blank">
</a>
