KenB_Texas
I took my Saginaw 3 point off of my 44H and put on my 300 today, and I am not sure I got the hydraulic lines right. The hitch has 2 way cylinders but I am only hooking up for one way at the moment. (as it was on the H). I used the remotes at the back of the tractor and hooked one line to each with a breather on the cylinders.
The control switch on the valves is turned to the one-way position.
The hitch is working but I am questioning if it is correct.
Am I running on only ONE cylinder?
Should have used a ’T’ and put a plug in the other line, and if so which of the two lines is pressurized?
thanks
ken
thanks
ken
