Oil Slinger gear for 130
EZ
Does anyone out there have a "good" used, not worn out, or broken oils slinger gear for a 130?
The part # 354643-R11. Tooth count is 41.
There should also be a good bushing on it.
Let me know.
I have one hanging on the wall in my shop thats used in good condition. Not sure of value. let me know if your interested, Dan
Dan,
Is it possible to get a picture of it? Including a good close-up of the teeth?
A couple ways to measure it's wear:
If you measure width of the top of each tooth, a good gear will have 1/8" or more left on it. I have a worn out one which has only about 1/16" left on it. Also note whether the sides of the teeth are beginning to "curl" over especially on back side of the teeth.
If you have that part#, and the gear has a good bushing, we can start talking about value.
Do you know what tractor it came out of?
(quoted from post at 18:51:58 04/23/09) I have one hanging on the wall in my shop thats used in good condition. Not sure of value. let me know if your interested, Dan
Dan....are you still out there?
Have you had a chance to take a peek at that oiler gear?
Ed
Ez,The gear came off a super a, the width of teeth across the top is 1/4 of an inch. appears to be in good condition. Has 41 teeth,I may be able to come up with a picture in a day or two. Dan
(quoted from post at 18:28:50 04/25/09) Ez,The gear came off a super a, the width of teeth across the top is 1/4 of an inch. appears to be in good condition. Has 41 teeth,I may be able to come up with a picture in a day or two. Dan
Dan, that 1/4" measure. Is it between the teeth? How wide is the top of the tooth?
From looking at my broken one, 1/4" between the teeth would make the top of a tooth at or better than 1/8".
And also, to verify, the part number is 354643-R11?
I paid $20US for a good used one last month, unfortunately, it was the wrong gear and it is of no use to me. I'm trying to put my 130 back together.
Thanks,
Ed
Same part no.,as stated before it's 1/4 inch wide on the top of the tooth.30.00 dollars US plus shipping. Dan
(quoted from post at 06:21:29 04/26/09) Same part no.,as stated before it's 1/4 inch wide on the top of the tooth.30.00 dollars US plus shipping. Dan
Dan,
Seems fair to me.
Could you send me an email with following;
A couple pictures of the gear.
A phone number where I can reach you.
A shipping price.
That way, after I have your ship to address, I can ship you payment, afterwhich when you've got cash in hand, you can ship me the gear.
Thank-you,
Looking forward to hearing from you again,
Ed
