Cub Cadet 129 Clutch Problem
bleisinger
New User
I just replaced a worn brake disk, and thrust button on the clutch to my 1972 Cub Cadet 129. The problem now is that after I engage the pto, when I go to turn it off the brake disk does not line back up in the three grooves of the main clutch assembly. It does stop the PTO but I know it isn't right. Thanks in advance.
How much "free-play" do you have with engine off & clutch lever ahead [engaged]? This would be at the clutch button to the engage/ dis-engage lever.
Are all 3 bolts adjusted evenly? Are the 3 "triagular" pieces which seat in the clutch button groove in good shape? Let us know.
(quoted from post at 03:51:12 05/01/09) How much "free-play" do you have with engine off & clutch lever ahead [engaged]? This would be at the clutch button to the engage/ dis-engage lever.
I got it working, just had to tighten the clutch assembly so that the brake disc was down in the grooves. Thanks for your help.
