Where to find three blades for my Cub lowboy?
Anonymous-0
Where to find three blades for my Cub lowboy? I believe the deck to be a Cub 22 deck. How could I get more power out of the Cub lowboy. I believe it to be a 1965 model. It has a International carb on it. I will try to get pictures of it posted. Thanks
You want more power on the tractor put on a small pulley the bigger the pto pulley les hp you will have
(quoted from post at 10:25:59 05/02/09) Where to find three blades for my Cub lowboy? I believe the deck to be a Cub 22 deck. How could I get more power out of the Cub lowboy. I believe it to be a 1965 model. It has a International carb on it. I will try to get pictures of it posted. Thanks
Pictures aren't detailed enough for me to tell model number of the deck. Could be IH, Woods or Danco. What is the length and mounting hole specs?
agrisupplyDOTcom sells blades for both the Woods deck and the IH/Danco.
To get more power, first try a tuneup.
If that doesn't help, you have to rebuild the engine.
There's not much you can do other than that.
