Anonymous-0
Bought tractor in Kansas last year. In the process of repainting and upgrading. Previous owner removed Ensign regulator and replaced with Century. Run small Max. line back to elbow at dicharge on regulator. I remounted regulator and put all lines back as they were. Now I can not get engine to idle. Can adjust main jet and smooth out engine at high speed, but idle jet will not work at idle. Any help out there?
If you put the ensign regulator back on it the regulator has a screw in it for setting the idle mixture and the carb ajustment is for rpms only at the governor shaft.
