How to remove PTO on H
Arf
New User
I am trying to remove the PTO on my H farmall and I am having no succcess. I removed all the bolts and pryed on the plate and it does not come out. What am I doing wrong? If it matters it is a 1940 model so it does not have the housing outside of the rearend just a plate that bolts to the rearend.
Unless there is something seriously wrong inside, the whole assembly should just pull out. Probably just stuck with the gasket. Are you positive all of the bolts are out?
I can move it a bit and so I know the gasket seal is broken. I know in the picture the bolts are in but that is just to keep the rain out while I am trying to figure out the problem!
It should just come out...
Try wedging screwdrivers all the way around to pry as evenly as possible on it... no warranty from me if it breaks, though.
From the diagram shown, the only thing I can see is a possible interaction with the internal lever hitting the tractor housing, can you move the control? It looks in the pictures you posted like it is straight up and down, not sideways like a push pull would work. JimN
caseih.com parts H attachments PTO special
Actally the reason I am removing the PTO is to try and fix the engagement lever. Currently I can pull the engagemnt lever all the way out and see where a pin that goes through it is sheared off.
I will bet that the issue is that internal lever that is now not connected. It may have dropped down confounding the removal. If looking in the hole does not provide a way to turn the inner lever, It might be able to be fished up from a drain, or Pulling the top off (Sorry about that last idea) JimN
Janicholson, I cannot open the link on your first reply. Can you e-mail me the info?
Go to caseih.com
Choose North America
At the top of that page select parts and service
select find parts
put farmall in the white box
scroll down the list till H appears
select H
below that will appear several categories
select attachments
select the first Power Take Off Special
It will look like yours. Jim
