IH 784 3-point raises when I raise the frontend loader
Anonymous-0
Hello, I am using a friend's 784 to clear brush and now it seems to want to raise the 3 point(has backblade attached now)when I raise the front end loader bucket and the 3 point seems to chatter now when lowering and raising-- is there a splitter valve on this machine that I may have opened that cases this? Also notice there is no oil pressure gauge- I assume the oil light is the one on left of the panel and its on! They have been running it like this--is there a chance the sender is faulty-is this common?
The engine oil pressure warning light is on the top of the WARNING LIGHT PANEL, in the second from the right position. The Transmission Oil Temperature Warning Light is on the top left if (and ONLY if) it's a Hydrostatic equipped 784. You will know this is a Hydrostatic 784 if you have a "Foot-n-inch pedal on the left instead of a clutch pedal.
