Hit and miss
jake70d
New User
I have a hit and miss motor my grandpa gave to my dad. It is leaking fuel out of the pump. i was wondering if anyone knows if they make new ones or do you have to make them and if you do what do i use.
more than likely you just need to replace the packing, pump check balls, and the pump spring and the pump will work as good as new. 99% of the time that is all that is needed. Check with Starbolt Engine Supplies, I have added a link. I have had no problems with their parts on the IH and Hercules engines I have worked on, but have had problems with another suppliers parts not fitting.
