International H
Susy
New User
Tractor runs good. It has a 3 point hitch and a power take off on side. No tag for serial number any help please. Need to sale. Thanks . In south Alabama.
The serial tag should be on the left side of the clutch housing. If it is missing, you can find the engine serial number, which is usually the same as the tractor. You find this stamped on the right forward side of the engine. Then you can take that number, bring it back here to YT, look under Research and Info and get the year of your H. That will help in determining a price, as will condition.
Take a picture and post the add on the "Photo Ads" section, and hopefully you will get some takers.
If it starts and runs good, no smoke, no noise in rear end and stays in gear, with very good sheet metal without dents and rust pitting, if the 3pt. is good, and tires and rims are good, it would be $1500 to $2500 depending on how much someone wants it. If any of those things aren't in good shape or working properly the price would be lower. The 3pt. adds about $500 if it's working well. Anyone buying it to restore would want a good serial tag on it too. It would be on the left side, (as you sit on it), forward of the battery.
Best of luck.
