Farmall hyd. pump?
gpogpo
Anyone know where I might find a cam gear hydraulic pump to fit an H? I'd like to power an older loader with hyd. bucket with it. (Do these pumps have enough output for that purpose?)
One from super H -350 will work but need to change front cover and make sure you have a heavy cam gear, few out there with M&W pumps that will bolt right on, yes they will run your loader fine, good luck Here is a picture of one on my Blue H I put together.
Couple more questions Mike: Is the M&W pump the same as the optional Farmall pump? Do you have any idea on the output flow of the pump?...(to run a small loader). Can the pump be installed on a late model H using the original cam gear? Was it fairly easy to get your H retimed with the new pump? Thanks again. John
