(quoted from post at 08:46:21 06/22/09) What is your procedure for polarizing the generator?
Is your tractor set up as postive or negarive ground?
I can't tell you anything about this, but found on the WORLD WIDE WEB.(quoted from post at 13:46:40 06/24/09) Ok, another question here. Why doesn't some co. offer a solid state regulator for these oldler model tractors. Sounds like a simple enough unit to build . I know , not enough demand to make it profitable. Deere uses a simple diode in place of a mechanical point type cut out relay on some of their old beaters. Also, the vibrating point mechanical voltage regulator has to make and break many times a second so easy to see why if points don't make good contact each and every closing the voltage will be fluctuating. They tell me the zenor diode used in solid state regulators can interup current flow up to 7000 times a second. Don't know the guy who was sitting their counting this.
