806 mvc gear replace
You will have to split tractor at clutch housing,remove bolts from bearing holder,then remove bottom plate,also remove input shaft assy. then there might be enough room to slide gear of shaft then out bottom. If there not room then it will have to be split again to gain more room.This all from memory it's been awhile.Any more questions ask for the Tractor Vet.Scott
