super h 3 point hitch
jeffkirlik
New User
i am looking to build a 3 point hitch for my super h. does anyone know where i can find a good set of drawings to go by? thanks for the help.
I would think that how much heavy work will you do when done. If all you need is a blade for moving snow it wont take a lot. You can hook a three pt blade to the drawbar and use a two-way cycl for the center link to raise and lower.just use the side of the cycl to lift and your belley pump will work just fine. Get a bush hog mower with wheels and use a single cycl to lift it.So do you really need three pt. I have been using a blade on a B for 25yrs for snow removing using the Char-Lynn power pac for hy.
I'll second on the Saginaw hitches, mine has been great. Its also really easy to install no fabrication or anything like that.
