Farmall 140 rear axle housings
Anonymous-0
My one Farmall 140 tractor was obviously used by a road department and rolled over sometime in its life. The rear final drive housing on the right side of the tractor had a little crack in it and now that has really expanded. Can i use a Farmall Super A housing or is this substantially different. Does it have to be off a Farmall 140 to work on it?
Thanks
Jay: The final drives changed around Super A serial number 350000. After that number and all 100, 130 and 140 are the same. Final drives on all Super A before 350000 are different. The difference is the change in brakes.
350000 is not the exact number, but close, check an IH parts book for the exact number. Definitely between 340000 and 350000.
