Farmall A hydraulics
Good Afternoon Bob,
Some fellas have fabricated hydraulics on their A by using an old power steering pump, and running it off of their fan belt. You would need a couple of brackets and a larger fan belt to accomodate another pulley.
Try doing a search and you may come up with some older threads on this issue !
scotty
http://ytforums.ytmag.com/viewtopic.php?t=256223&postdays=0&postorder=asc&highlight=hydraulic&start=15
Jim: You also have to change the torque tube, Super A torque tube is flat on top to accomodate factory hydraulics. Farmall A torque tube is round on top. Most will agree, you may as well go buy a SA, as change both block and torque tube.
(quoted from post at 16:21:43 08/17/09) I also saw someone on here run the pump off the belt pulley.
Running from the crankshaft pulley would be easy, too...
True if going for a full IH based system. I was just getting a pump on it, assuming the system would be adhock as well. Jim
