WD6 Fuel lines
Anonymous-0
I have a leaking gas line that runs from the starting tank to the carb. It leaks where it connects to the sediment bowl, and to the carb. Where can you find new fuel lines for these tractors? I would also like to get new lines for the diesel side to. Thanks
Sometimes taking it apart, cleaning and putting it back together works. If not get copper tubing and fittings and build your own. Lots of times the bottom of the tank is rusted and thats where the real leak is.
Brian
