10-20 air cleaner
We have our 10-20 painted, decals installed, and ready to go. What type of clamp held the oil cup to the air cleaner. In the old days we just had a wire on there. We would like to make it orginal.Thank you for any help.
Henry
What year is that? It seems there was a change in the air cleaner, so the real early ones are beyond my knowledge; regardless, I'm thinking most had the wingnut configuration [with tabs on, or a bar across, the oil cup] but I haven't looked at mine recently.
It is a 1930 according to the SN. I will try to make one using eye bolts and a bar across the bottom so it will look like yours
TX Henry
I took a quick look this morning:
without a grabbing tape measure and calipers, I'm thinking your cup & the retaining parts might be directly interchangeable with a later Regular Farmall or a F-20 [from start to, perhaps, all the way through] even though the top casting would be different.
My 10-20, IIRC, is about a year newer than yours, but I'm rather sure it was several years earlier [if at all: sometimes I get 15-30 knowledge confused with that of the 10-20 despite, or maybe because of, the often overlapping technology] for the major change I was thinking of.
Good luck!
