Grill Screen on Farmall M
Anonymous-0
Hello. Got a question for you all about the wire mesh on the grill of the Farmall M. Were can I get replacement mesh? Can I restore the one that is in there? If, so best method you all have found. And finally how to you get if loose form the grill? THANKS ALL
I answered a similar post below. Carter and Gruenewald sells the correct screen, you cut it to fit. 866-327-6255. They are a Case-IH dealer in WI. Carefully pry the tabs up from the grille, if some break, you likely have enough left.
