Sleeves for F-30
Anonymous-0
I need to pull the sleeves on my Farmall F-30, I ordered a disk for my sleeve puller but it is the wrong size. Does anyone have a Farmal F-30 sleeve laying around that could give me the outside diameter? Thanks Dave
Call Rice Equipment at 814-227-9200 to see if they have a sleeve and can measure it. Your puck needs to be undercut to 4.05" to fit the bore of the sleeve. Hal
PS: Thefordsonhouse in MI may be able to help you too. 906-786-5120
I just measured one and it is 4.75" at the bottom where it seals to the o-ring and steps up to 4.875". Gotta be careful as the bottom of the sleeve only hangs down past the web in the block maybe .187 or so. Good luck.
