Anonymous-0
How often should I expect to have to add water to the radiator? If I use it to plow or disc for an hour or so then I usually need to add about a qt of water. (I know if I fill the rad to the top some water will be forced out when the engine heats up)
The engine doesn't seem to be running real hot, radiator doesn't leak and I don't have any water in the oil. Just need to add more water more often than I would expect?? But maybe this is just normal?
Pete
Pete
