1466 clutch
About like rebuilding a wheel cylinder , I like to run a brake hone thru them with a fine stone and wash them out with hot soapy water till they lightly rust and lube them up and put the new O/Rings in them
and your done .
i ment how to get to the booster and change it. do i need to split the tractor. i have not looked in to it to hard its more of a winter project. thanks
The hydraulic booster is just like a wheel cylinder, in the rod between the pedal and the lever for the throwout shaft. Some bolts, hydraulic line or two, and it pops right off. May have to pull a battery or something if you have the factory cab.
If you have something without the booster, 06-66 series, compare the clutch linkage and you will find it quickly.
