Anonymous-0
As a new member to this forum, I have a question I hope someone can answer. I was plowing snow last winter and my transmission started knocking. I split my tractor in two and found what the problem was. The bearing between the main transmission shaft and the transmission drive shaft was bad and the nose of the main shaft was damaged. I purchased a used main shaft today and and a drive shaft. The main shaft is mounted at the rear of the transmission with a triangular plate. there are several shims under this plate which set the gear backlash. Since I am replacing the main shaft with a different one from a different tractor. I need to set the backlash by adding or subtracting shims. I don,t know what the backlash specs are. If anyone knows this, please let me know. Thanks, Gordon Mercer, Spearfish, SD
