new IH distributor cap
Superih
Have you guys bought any distributor caps from CIH? They seem to be identical to the Tisco caps. Both of these caps do not have the number "1" molded on them and they do not fit the distributor tight nor do the retaining clips snap tight.
Apparently these are all that are available from CIH through CNH. They are pretty much junk.
Does anyone know where you can get the older original type distributor caps?
Two comments:
1. When I worked at a CaseIH dealership in 1995/1996, we gave up on CIH caps due to aluminum contacts and poor fitment, used Echlin from NAPA instead.
2. I now work at a NH dealership and a couple weeks ago we peeled the CNH label from a voltage regulator box and found a TISCO label on the box. The instructions for polarizing the system were incorrect for a Ford charging system.
I bought a cap for my A's mag at tractor supply it had the 1 on it fit nice and tite and has worked great for years. The cap for my H distibuter I got from napa also worked great for 2 years now
