Super A now running
testanley
I finally got my SA back together and running today. However, the engine has a serious Farmall surge when running. The govenor seems to work the daylights out of the carb. You can hold the rod from the govenor to the carb and it runs steady. Any ideas from anyone on how to fix it?
testanley: Surging is most likely adjustment. Broken spring usually give you little or no control. IT manual gives a good adjustment proceedure. If you don't have a manual, send me an e mail, and I'll try to give the nuts and bolts on adjustment.
