Nebraska Kirk
Spent some time working on my 400 Monday & Tuesday. Had to take the engine apart to have the crankshaft ground, so I decided to check out the TA and tranny/final drive as well. Good thing I did! I found several worn parts in the TA and main clutch. It was a good couple of days in that I got everything apart without too much trouble, but bad because of bad parts I found :'( Oh well, it is only money, there goes this week's paycheck :'(
Before
Started
IPTO drive shaft has worn splines
Matching splines in clutch backplate are VERY worn :-(
Splines worn on TA sun gear
Worn and pitted crank journal
Before
Started
