speedi-sleeve for 300 live pump
mkirsch
Is there a speedi-sleeve to fit the rear seal of a 300 live hydraulic pump? I'm getting oil in the distributor.
(quoted from post at 04:15:32 11/08/09) Is there a speedi-sleeve to fit the rear seal of a 300 live hydraulic pump? I'm getting oil in the distributor.
That may not help if your shaft and bearings are worn. That allows too much oil (and pressure) to get to your seal. A seal is only good for 3 psi.
My seals got pushed out twice, bit the bullit on a new pump.
