504 Wheel weights
STEVOd
New User
I need to get some front & rear wheel weights and was wondering which models use the same weights as a 504. I was told H & M are the same-anyone know? Thanks
C though 86 series all use the same rears. for fronts you need them off a 560-460 etc... series. or you can install a suite case bracket and go that way to.
Andrew
You didn't indicate whether it is a Farmall or International. If it is a Farmall, the bolt circle of the rear weight will be 17". Seems like every C, H, and M plus later Row Crops will have at least one set. Every salvage yard will have a pile of them. They come in one piece or two piece configurations. Two piece are good for weaklings and those that want inside of wheel mounting.
The fronts are tough to find and when you do they're expensive unless you're one-in-a-milliion lucky, and find someone who doesn't know what he has...
That's because by the time the 504 came around, front wheel weights were falling out of favor. Rather, the removable suitcase weights on a rack in front of the tractor design was becoming popular.
