501 ci K series in Farmall 460 or 560
eplecker
New User
Would like to know what is involved in installing a 501 ci K series truck engine in a Farmall 460 or 560. Any help is appreciated.
it's a great puller in fast class , feller has one in CVATPA . nice tractor must bolt right up as no adapter plates are allowed in that class.
We have been working on one for a little while now. You can use the factory plate to mount the motor but you will have to re-drill some holes for the motor to mount to. Also, either the 560 flywheel has to be machined to fit on the truck motor or you will have to have a flywheel made. Kenny"s pulling parts in Kentucky can make you a flywheel or you can buy clutch and all from Custom tractor parts. We used 806 frame rails.
