cub hydraulics
david-cub 52
New User
recently purchased a 1952 cub with touch control hydraulics and i do not seem to be able to get the hydraulics to park or stop . It seems like it is always working. either wanting to move the rock shaft up or down. ? is there an adjustment for this. or since i do not have any attachments can i disconnect the hydraulic pump so it will not work any more
The control valve is not adjusted correctly.
Try this link. The instructions for adjusting the Touch control are here.
http://www.cleancomputes.com/Cub/
I have a simlar problem on a Super C. The hydraulics will get hot after about 30 min. of operation. I have taken it apart and cleaned everything. I have not been able to find the problem. The book refers to a crack in the housing. Good luck!
