Yesterday I got the rear scraper done. Was dark when I used it, needs a bit more weight. Was impressed the tractor fired right up at -6.
used one side of the lift for the rear blade and will use the other side for the front.
Gene if you read this, what special maintenance do I need to do when using the pneuamtic lift in freezing weather??
